Z28 '01 broke: 4 belts, 3 alternators and 5 bateries in less than 6 moths HEEELP!!!
hello fellows oe year ago I joint you in the Camaro owner adventure, it was my very first car, and I love it (and respect it) the car was stock so I know every that is related to mods in this car, Im going to make a small list of stuff I put in my car so any of you can tell me why I did wrong
-keyless system + push start Buttom from http://www.advancedkeys.com
-pioner AVH-P8400BH + rear camara
-camaro sound kit from doubledmods.com (nothig speccial just new speakers) and the double din dash
-one star (my family force me to do it...)
-BBK 85mm Throttle Body
-BBK Underdrive pully
now lets go to the damage history:
04/03/13: battery drained
04/15/13: directional light bulb burned
04/23/13: alternator broken
04/28/13: belt broken
05/0x/13: brake light bulb burned
05/25/13: belt broken
05/28/13: directional light bulb burned
06/14/13: battery drained
06/30/13: battery drained/ alternator broken
07/0x/13: directional light bulb burned
07/15/13: belt broken
07/27/13: battery drained
08/25/13: alternator broken
08/25/13: brake light bulb burned
09/02/13: belt broken
09/18/13: battery drained
09/20/13: car is starting to show low charge... AGAIN!
the car some times turn of in Idle, is just like it cannot hold the RPM by itself, steering wheel and brakes are getting harder... until some day the car wont start or it turn off, or it broke the belt... then I buy the new part and everything is good again...
don't know what is wrong with the car
I really cannot keep spending +600 dollars in the same stuff each month
I need some help!
:b omb:
I need some help!
:b omb:
with all the electronic modifications you did I would look at all the grounds (negative)side on everything you installed. sounds like you need to check every ground. good luck! the oldman....
