Re-installing A/C, what is needed?
I already know the Accumulator and filter should be replaced, but my big concern is if the Condenser (radiator looking item that mounts in front of the radiator) needs to be replaced. Mine has been sitting in my garage for the last 3 years, but is still in good physical condition.
Car is a 1999 Trans Am, H/C/I. The one other question is i had the engine tuned with out A/C, does this mean i will need to get it put back on my tune, or will just the low A/C indicator not trip the SES light?
I don't know what you were referring to when you said filter.
Now with the Evaporator, i was thinking of having a shop flush just that part out since it tends to collect the most crap throughout its life. Is this even necessary or would i be fine with a/c flush solvent? I capped the tubes off as well but it has been sitting in the car for 3 years and i am sure water or condensation has built up in there (i live in WA and have to change my brake/clutch fluid every year) over time.
Does anyone know how many volts go to the compressor to turn it on? If it is 12 volts can i just make a quick jumper wire from the batter to the compressor to test the clutch activation? I tested the line and was getting only 0.5v while the car was on and it did not change when i turned the blower on or the A/C on.
I replaced alot of stuff on it, but i have not filled it with R-134 yet as i was gonna have a shop do it. I just wanted to test the compressor, first. Cause if the compressor does not work, then their is no point to get it charged.
if you want to check for leaks, you put a vacuum pump on the system and pull it down hopefully to around 1000 microns, ideally less, and see if it holds. ask the shop what 'pressure level' do they pull vacuum to and what kind of gauge they use to measure it. don't use the word micron. if they don't say what i said consider finding someone else who's competent. hopefully they're just looking to charge you for oil to make extra $$$ of you.
