1998 ls1 temp question.
Best thing to do is see them spinning. These gauges are not accurate. But if you are just going up to a true 210 degrees when sitting in traffic that's not bad at all.
If a tstat starts to stick partially open.....sometimes when it finally pops full open the coolant will cool down fast and the needle will drop fast.
I'm using the SLP 160 stat, but from the looks of the SLP one, its as generic looking as a autozone part.
ALL of the earlier ones were only available permanently mounted in the alloy housing, whereas the latter ones (Vette/GTO and last year f bodies) looked like any old 'generic' T-stat, which was separate from the alloy housing.
