O2 sensors going bad?
"....can this clicking noise be due to my o2's failing? " Do not think so
I think clicking would be a exhoust leak between head and header flang.
could be header bumping frame/body, but do not think so
my .02' Johnny
ps check the header bolts<<<
".. The header was welded on to the y-pipe so it's possible that it wasn't welded completely." do not think so ... ticking/clicking come from flange to head being loose or warped flange
Johnny
When I got my 427ci installed and my 1 7/8" headers.....same complaint I had to my builder/installer. He said that's what it was and that in time I won't even notice it anymore.....he was right. The only time I hear it now it when I drive along side and close to curb and that ticking noise bounces off the curb and makes it more apparent. Then when I'm clear of the curb its gone.....
If you have no leaks that's probably what it is.
And no.....02 sensors make zero noise. You may get codes soon because headers get a lot hotter than stock exhaust.......you will have to get Denso 02 sensors....they handle that heat better than the old AC Delco sensors and better than the Bosch.
Also, maybe check for a broken spring(s).....that makes that valve train tick a lot more noticeable.
