Sponsored by: CARiD
SS trailblazer, Temp gage not working causing poor starting
Old 11-01-2013 | 10:42 PM
mferlito's Avatar
Default SS trailblazer, Temp gage not working causing poor starting
Any one had this problem, temp gage working then goes to "0" , truck starts running bad, fast idle. On next start up truck just spins over for about a min then starts like it's rich,
HELP !!!
Old 11-01-2013 | 11:39 PM
LS6427's Avatar
Change the Coolant Temp Sensor......
My 1998 PCM will not let my engine run its a failing Coolant Temp Sensor.....it barely starts, and when it does it backfires and spits raw fuel out the exhaust pipes. If you touch the throttle it stalls.
And NO......you will not always get an SES light or a code......
Maybe that's your issue too.....
Old 11-02-2013 | 10:45 AM
mferlito's Avatar
Smile Thanks for quick feed back
Thanks, I will give that a try, it has been to the dealer twice with out any results but two new thermostats
Mike
Old 11-04-2013 | 01:05 AM
LilJayV10's Avatar
Mike
Why did they replace the thermostat? I'm going to guess because there was a code for engine not reaching the correct temp?
LS6 is spot on with replacing the ECT.
If you have a scanner look at the what the ECT value is. I had a F250 about a month ago the CHT(does the same thing as a ECT does)that was bad and it was telling the computer it was -35 degrees and it was dumping a ridiculous amount of fuel. It wouldn't start unless you held the throttle to the floor which puts it in flood mode and shuts the injectors off.
Quick Reply: SS trailblazer, Temp gage not working causing poor starting
