Changed P/S pump...only 1 quart. Problem
Before starting the car I filled the reservoir. It took about 3/4 quart. Started it and made a little metallic type noise which seemed normal from changing the pump on my old caddy. However with that when I started to turn the wheel it went away.
Now with my install on the 01 ss I bought the noise just stayed there and it didn't take anymore fluid. Almost seems like the pump isn't pumping any fluid and it's just sitting there.
Any ideas? I'm sure the pump is shot at this point either way because I continued to turn the wheel for a bit thinking maybe it would start to take the fluid.
Thanks for any help
tried other methods, this was the only way that worked for me to get the water out of the pump, also don't forget to bypass the oil heater/cooler thing..
