Help identify Squeal (video)
Your brake light is probably just a dirty switch at the parking brake handle under the console. (It's in the same neighborhood as the shifter.) Maybe your stick is knocking up against the wire for that? If you take the center console out, you should easily be able to get to the bottom of that issue.
On the sound, it might be a bad wheel bearing. I don't have a lot of direct experience with the rear bearings, so maybe someone else can chime in on that one? It might also be the new brakes dragging. Did you lubricate the slider pins when you replaced the pads?
Maybe this might give you an idea of what to look for....good luck!
But....a friend was going to swap rims with the front rim and go for a slow drive to see if that solved it. Then he was going to remove the caliper, put the wheel back on and go for a drive to see if it stopped. That was his way of narrowing it down to....rim, then caliper/brakes, then to the bearing.
Have you tried just jacking up that wheel and freespinning it by hand to see if you can hear the squeak? Try this first and you might actually be able to hear it and track it down. Also, if that doesn't work. Take the wheel off and inspect different areas of the inside of it looking for "shiny" marks indicating rubbing. Check the pieces closest to the rotor and see if any of those are making contact, again looking for "shiny" areas. You'll find it, just keep at it and you will eventually have your "Ah Ha!!!!" moment.
