PS Functionality linked with Alternator?
My alternator is practically new, but I think a leaky tail light housing causes electric problems whenever it rains. Sometimes on startups, it would take about a minute for the charge needle to go from the off position to the charging position. The confusing thing though is that when this happens with my new alternator, the power steering is out for exactly the time that the charge needle is at the off position, and kicks on right when the needle goes to the charging position. When this happened with my old alternator, my PS was never affected. And my RPM is at the normal range the whole time...
The LS1 PS system is strictly powered by the pump right? If so, how feasible is it for build up moisture to cause a worn belt to constantly slip on the drive pulley, thus causing these symptoms?
Any help is greatly appreciated, and a Merry Christmas to all.
Another thing to check would be your belt routing against the diagram on the shock tower.
