Need a New Radiator
With stock fan settings (not sure if yours are stock or not) and the A/C off, you shouldn't have any fan engagement until 227°F (low speed) or 235°F (high speed). You'll need a scanner to verify exact coolant temp.
I used a 5/8" vacuum cap/plug on the lower driver's side extra opening and retained it with a spring type hose clamp (these hold tighter than worm hose clamps in the changing temp environments in which I live
).I replace this every year just to be sure their are no leaks due to it deteriorating/cracking.
Mine is usually just a hair under 210°. You may still have some air pockets in the system causing temps to show a bit higher than usual.
Is there a way to have them kick in sooner other than having my edu reprogrammed or the SLP fan switch
