Sponsored by: CARiD
Need a New Radiator
Old Dec 30, 2013 | 02:24 PM
barkerpa3466's Avatar
Default Need a New Radiator
Hey all
I need a new radiator the plastic is cracked on the hose hook up on the drivers side of the engine. I was just wondering if there is a preferred brand as far as quality goes.
Also I wouldn't be opposed to going all aluminum if any one knows where to find one for around 200.
Thanks
Car is a 02 z28 with a T56
Old Dec 30, 2013 | 02:40 PM
Empatho's Avatar
Get an lt1 radiator they are thicker then ours and they fit in without a problem.
Old Dec 30, 2013 | 03:04 PM
fruitsalad's Avatar
If you're willing to spend ~$500, I'd recommend a Be Cool or a Ron Davis. If not, I'd look at Champion ($150-300), although I can't remember whether they have a model for either LS1 or LT1.
Don't forget if you do go LT1 that there's one port you will need to cap off.
Old Dec 30, 2013 | 04:08 PM
Spartan7's Avatar
If there's nothing wrong with the core, save yourself some money and find a radiator shop that will replace the side tank. Should be around $75.
Old Dec 30, 2013 | 06:21 PM
Thanks for the input
I found the champs for 200 its a 3 row....I'm thinking about it but it seems like over kill and i have a feeling there will be some fitment issues.
Currently looking into the lt1 swap.....how would the extra port be sealed?
Any one get a replacement either lt1 or ls1 from one of these manufacturers? were they any good?
SPECTRA PREMIUM
VISTA-PRO
ACDELCO
I thought about having the ed cap replaced but for the extra few bucks i figured it would jut bet better to get a new one.
Old Dec 30, 2013 | 08:23 PM
fruitsalad's Avatar
Vista-Pro and Spectra/Spectre whatever they are generic replacements, i.e. eBay and cheap store brand stuff. Delco is OEM GM.
If Champion says it fits in a 98-02 F-body, take them at their word and buy it. No such thing as radiator overkill! Your engine will be happier, especially in the CA heat.
For the LT1 swap, you can use a rubber plug from a hardware store to plug the port--$3-5.
Old Dec 31, 2013 | 11:42 AM
I'm at the Pick n pull all I have are 96 to 97 v6 cars is the radiator of lt1 the same as on a v6 cars
Old Dec 31, 2013 | 11:58 AM
NnOoSsSs's Avatar
I got one at autozone that is thicker than the stock for like 100 bucks. Just need to get a cap set so you can cap off one of the plugs
 Michael S. Palmer
Old Dec 31, 2013 | 12:14 PM
I might end up doing that......but is the v6 the same as the lt1because there is a nice looking one here that is still all sealed up it is in a 94 v6 auto.
Old Dec 31, 2013 | 12:18 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Old Dec 31, 2013 | 12:28 PM
NnOoSsSs's Avatar
Boom.... there it is
Old Dec 31, 2013 | 12:47 PM
Well that was a bust....going to AutoZone to order an LT1 radiator....does any one have pick of the location that needs to be plugged and or part number and or size of the plug
Just want to throw in one more and or for the Hell of it
Thanks for the help everyone
Old Dec 31, 2013 | 12:56 PM
NnOoSsSs's Avatar
Im sure itll work out for you. If you want just in case buy like one of their cap kits
Old Dec 31, 2013 | 01:06 PM
the 1st chart I supplied showed radiator assemblies.
this chart shows where cores and end caps are similar/same.
Old Dec 31, 2013 | 01:27 PM
LS6427's Avatar
Don't just cap that port off.
Here's what you do. Buy an 8" piece of 5/8" heater hose and a clamp. Then go to Home Depot with that hose and find a threaded brass plug that will screw into one end snuggly. Then also a clamp for that end.
That's what I did when put an LT1 radiator in. This way you have a great way to flush the system when needed. It flows out like a garden hose.....instead of that factory petcock valve that takes forever to drain.
The extra port is on the back at the drivers side bottom corner. It faces straight backwards and when you use it for a drain the coolant will spill out right onto the ground.
You will run cooler than an LS1 radiator will do. And to be honest......all of those aftermarket radiators don't do anything at all to cool better. They are good for boost builds and full race builds.
......NOTE: while you are at the auto parts store picking it up.....verify that it's. 5/8" hose that fits onto the port......it's been almost 10 years since I did mine. It's either 5/8" or 3/4".
Old Dec 31, 2013 | 01:35 PM
Well AutoZone only has spectras and they are the same part number from 95 to 02...O'Reillys has one from a.company called Murray.......are they any good......I am checking the part number now
Old Dec 31, 2013 | 02:01 PM
LS6427's Avatar
Check rockauto.com..........
Spectra is fine too.
Old Dec 31, 2013 | 02:18 PM
LS6427's Avatar
If you want to make sure you actually get an LT1 radiator.....and to make sure you don't get one with an automatic tranny cooler built in........I'd go to the auto parts store and make sure it has that extra port and no cooler inside the passenger side plastic tank. Looks like on rockauto.com some of the radiators under the LT1 years have the port and some don't have it. Strange.
If you order an LT1 radiator from 1995 without tranny cooler you should get the one with that extra port.....
Old Jan 18, 2014 | 12:04 PM
I am currently trying to install the new radiator but I am having an issue trying to get the old radiator out every thing is free except for the clips on the passenger side is there any trick to getting this thing out with out un-hooking the tube to the ac condenser
Old Jan 18, 2014 | 12:50 PM
Got it just took the battery completely out and bent the tube a little
