LS1 crank no start condition
and if you don't feel like reading all that heres a quick summary
changed pushrods (correct length)
No start condition checked already:
-coolant temp sensor
-checked ground wires
-grounded a plug found no spark condition
- used a noid light to find out no injector pulse
- no rpms being read during cranking on the scan tool
my questions for you guys:
Does the crankshaft position sensor control the injector pulse or does the PCM?
Should I rule out the Camshaft position sensor because it did not set a DTC?
any help would be appreciated
Crank position sensor
Cam position sensor causes a no start condition however the crank sensor eventually takes over and you can start the car after cycling the key three times
Fuel pressure issue, pump going bad
Ignition relay
Coolant temp sensor being bad will cause the car to run like crap, or put the car into limp mode and dump fuel assuming the engine is cold
There is also a trouble tree for no spark that will walk you through the steps it's the only way to reliably fix it or find the problem without throwing parts at it and wasting a bunch of time.
If you have ruled out the sensors I would go ahead and get a different PCM. Make sure your connections to the ignition coils are all plugged in. You will need a 98 PCM only
Do the easy stuff first. Fuel. Spark. Then start backtracking to the wiring harness or PCM or fuel pump if one or both of those are not present.
And as others have said. You can unplug the cam sensor and it'll still fire. The Crank sensor is the one that will cause you issues.
One other question - is it turning over and just not firing?
