engine vibration issues please help!!!
Lets start over, when you put it on the lift and unbolted the convertor did you try it 1st then let it back down and felt it was gone? Can you only feel this vibration or is there noise like an exhaust rattling vibrating type of thing?
Do you notice this vibration while driving OR only when stopped revving it?
Also inspect the lower engine pulley , its the harmonic damper for the crank shaft. Look to see if its rubber parts are coming apart or if the center bolt that holds it on is loose and while its running if it turns steady without shaking around or wobbling.
Also try running the engine without any belts for a short time to see if that changes it.
Also did inspect the flex plate for cracks when you changed the the convertor?
I had a similar problem on my 99 ta but it never got bad enough to worry about. I never really dug into it but I'm sure it was a worn thrust bearing on the crank. The oil pressure would drop as I give lite throttle then come bk up too. It caused by the crnk walking back and forth. Soor y for the poor spelling I;m tired.
I had (have) the same thing on my 02 Z28 with 124K and I've felt it on other high mileage 4th gens....even the v6s too.
1. I rebuilt the trans (but it needed it)
2. swapped the TQ converter twice (but I wanted a lower stall)
3. Put in a built LQ9 (great upgrade for these cars)
4. Rebuilt the rear end with 3.73s
5. Replaced all the accessories and pulleys except for the belt tensioner and the PS pump.
The car is almost fully restored now and it still has that intermittent (but consistent) vibration at 2000rpms.....very faint but its still there.
The guy who installed my engine thought it might be the exhaust....cats and / or muffler......but who knows.
Next will be the main belt tensioner....but the thing is eating belts so that needs to get done anyway.
Let me know what you find......
Good Luck
The balancers are hard to inspect and hard to install.
