Not getting fuel. Hmmmmm
I checked the fuel pump fuse and it is fine. Could jt be the fuel pump itself? I can't remember but do you normally hear the fuel pump turn on when you turn the key to the on position? I don't hear anything when i turn my key to the on position just the dash lights and the normal dinging.
Thanks for any help.
I've seen vids of people cutting a trap door above the gas tank to access the fuel pump....is it located in the same place on an '01 Formula?
Also, does the anti theft system cut the fuel pump out??
Again, thanks for all the help.
Want to see if its a bad fuel pump.......just turn the key to the ON position....then pop the hood and push the relief pin at the fuel rail. Make sure you use a rag to cover it so you don't get sprayed in the face.......see if fuel sprays out. If it doesn't, its a bad pump, pump fuse or pump wiring.
If it is your fuel pump.....DO NOT get another factory pump from the dealership. Get a Racetronix fuel set up. It's either cheaper or about the same.....but it's WAY WAY better. My Racetronix set up is now 13 years old and doing great. It's perfect for stock engines...... And it's good for about 550-600 RWHP.......
Thanks for the excellent info.
If so, they give you the 'adapter' pigtail and some of those heat shrink waterproof type connectors. Use this and make sure that you heat it until that plastic around the connector melts and seals the whole deal watertight.
Great performance from the pump, but has its pros and cons.
The only actual "con" I can think of is that it may not supply enough fuel for a BIG demand setup, like a built, BIG boost scenario, or a big displacement, high compression, HUGE cam deal with crazy large injectors.
In which case(s), YES, one MUST go to at least the higher volume Walbro, or Granatelli units, or if needs be the crazy expensive Aeromotive, or Fuel Lab, etc. in tank pumps.
Its a great pump no doubt. But my con's are that my pump is not always very accurate, the gasket it came with is a bit to small, the sensor at first would pop out but its been months after the last time it happend. Other than that my old pump must have been dieing slowly because this Delphi pump really feels like a nice power adder.
I bought the fuel pump from amazon and their packagaing for the fuel pump was no existant there was no foam or popcorn to hold the pump in place nor was it wraped in a plastice bag, i am amazed it worked seeing how it was packaged.
I know what you mean by Amazon's packing being **** poor though, as I once bought some 'boutique' oil from them (Eneos Sustina brand which is almost IMPOSSIBLE to find on a shelf, or even on other web sites) and it was the 6 quart case thrown in a much larger box with NO packing material what so ever.
I guess they have to cut corners somewhere to give those kinds of prices??
Well, they lost me as a customer who buys autoparts from them.
