Troubleshooting power steering pump leak?
so i been noticing that my power steering fluid was very low last month and the car (2002 camaro ls1) was making a whining noise on left turns.
I put almost a quart of power steering fluid and noise was gone.
2 weeks later i drive the car, and same noise comes back... half of quart of fluid was gone!!!
Is this a sign of power steering pump going bad or is this just a leak that can be tracked down? if yes, how?
Thanks in Advance
If not, you'll want to check your coolant dipstick for alien slime. If your coolant doesn't look right, your PS Cooler is bleeding over to the coolant system. If your coolant is clear, I'd think you should be able to see that kind of leak happening with the engine running.
If you turn the wheel all the way to the left/right, it may gush some fluid.
