Sponsored by: CARiD
Starting problem
Old Feb 10, 2014 | 05:07 PM
Frank12110's Avatar
Default Starting problem
I have an 02 trans am and it starts up perfectly fine but after its warmed up and i shut it off and let it sit for a half hour to an hour and go to turn the key to start it it just keeps trying to start but wont and then if I try it again it will start right up, has anyone else had this issue with there car and what could be the problem?
Old Feb 10, 2014 | 06:27 PM
ULTIMATEORANGESS's Avatar
plugs and wires ok?
Old Feb 11, 2014 | 10:18 AM
z28SSilvest's Avatar
Sounds like a bad crank position sensor to me. But hey, these cars are full of sensors so check everything down to the temp coolant sensor.
Was having problems with my old LS1 starting when it was warm, turned out to be a bad crank angle sensor.
Old Feb 12, 2014 | 11:13 PM
Frank12110's Avatar
Alright thanks how did you find out which sensor it was?
Old Feb 13, 2014 | 12:58 AM
chrysler kid's Avatar
Well these cars are relatively simple. Usually boils down to these parts
Ignition relay going bad Cause the car never to start
Crank position sensor can cause the car to die when driving, and cause no start issue
Cam position sensor can cause the car not to start immediately, it usually takes a few tries but the car eventually starts when the crank sensor takes over.
To me it sounds like your car is not calibrating the correct starting temperature for a hot car. It's dumping fuel thinking the vehicle is still cold. I would start with your engine coolant temperature sensor, but it could also be that your intake air temperature sensor is bad or your mass air sensor is going out
