Sponsored by: CARiD
Window roller size
Old Mar 2, 2014 | 12:20 PM
Dainius56's Avatar
Default Window roller size
So I am currently working on getting my driver side window roller guide sorted out but, I lost the roller some time ago. It's the one for the vertical track that attaches to the window that causes everyone so many issues. I've got a temp fix for now but looking into more permanent just need to know what size or diameter rollers people use since I lost my factory one. Also what are people using to imitate a roller? The help section at parts store isn't exactly the correct size. Any help would be appreciated!
Old Mar 3, 2014 | 07:20 AM
WhiteBird00's Avatar
Ungrounded Moderator
Moved to General Maintenance and Repairs section.
Old Mar 3, 2014 | 10:28 AM
wssix99's Avatar
Save the manuals!
The best thing is to get a new piece that rivets to the bottom of the window glass. It will include that roller. Here are two other threads that will help you out:
https://ls1tech.com/forums/general-m...dow-guide.html
https://ls1tech.com/forums/general-m...rt-number.html
Old Mar 3, 2014 | 05:42 PM
Dainius56's Avatar
Well I've finally got it fixed following FirstYrLS1Z 's fix in
Found a real nice mom and pop shop here that had everything I needed to finally fix this issue...All grade 8 hardware so don't expect it to be breaking anytime soon I hope... Works great just a little noisier with the oversized metal washer but nothing that's bothersome.. thanks for the links wssix99!
Old Mar 3, 2014 | 07:44 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
glad it worked,mine still holding up,the noise lessened with time/use.
