Electrical gremlins and fuel problems..oi
The electrical issue...once in a while my gauges will "flicker"/ Reset, and the radio will stop briefly as if it were a cd skipping. I've read that this has to do with the BCM. The fix is to solder the T points. Is that all that it will take to solve this issue?
Also, When under acceleration, my dash lights and headlights will flicker, and then in higher RPM's, the battery level will drop if im heavily accelerating. Is this normal? I've replaced the alternator with a load boss, and it still does it. Someone also mentioned checking grounds. Has this happend with others? I've read up on threads and people have mentioned grounds, but is that what the fix is?
If so, that could kill the charcoal canister by constantly flooding it and set codes, and maybe even hurt the sender and other sensors back there.
