Cylinder #1 Misfire
Old 05-02-2014, 08:52 PM
Spd-Kilz's Avatar
Arrow Cylinder #1 Misfire
My stock internal (longtubes +ORY + catback) 2000 F-Body is having a misfire on cylinder #1.
I replaced the plug and it didn't help. I then swapped the coil pack & plug wire between cylinder #1 & #2 to see if the problem moved, but it didn't. I ran the car for a little, and the misfire was still there in cylinder #1. The plug is fouled and smells like gas.
I since then pulled the valve cover to see if I could see if there was an issue with the valve seal, but I couldn't see.
What would you suggest the problem is or could be?
Old 05-03-2014, 08:59 AM
mjcotroneo's Avatar
If it's fouled you could have an injector that's stuck open instead I pulsing. If you're in Dallas you can bring it by my shop.
Quick Reply: Cylinder #1 Misfire
