Sponsored by: CARiD
idles high when AC is on
Old May 15, 2014 | 06:49 AM
josephholtinsurance's Avatar
Default idles high when AC is on
Its a 2000 camaro ss m6. I had a vacuume leak when I bought the car. I replaced all the pcv hoses with rubber hoses and brass fittings. I replaced the tps (throttle position sensor) and the iac (iddler air control sensor). I cleaned the maf and intake. Now when I turn the Ac or heat on it idles up over 15-1700 rpms. I turn the fan off and it idlesback down to around 800 rpm. I dont know what else to do. Help me out guys.
Old May 15, 2014 | 07:24 AM
1slowbusa's Avatar
Is this a stock car or has someone been in the tune?
Old May 15, 2014 | 09:09 PM
it has k&n ram air intake and flow master cat back exhaust. And is running on stock tune
Old May 15, 2014 | 10:07 PM
JustAFooL's Avatar
My car did that at times, never really figured out what caused it. Then I decided to build it and ditched the AC. It don't idle high no more.. Really though, I never could find out what caused it. Mine didn't idle that high though, it just bumped up to around 1100
Old May 16, 2014 | 09:43 PM
1slowbusa's Avatar
Did you find the problem?
Old May 17, 2014 | 07:59 AM
no not yet. I may look into selling my k&n intake and look into something else. Maybe go back stock and put the slp lid on. I don't have any other ideas
Old Jun 15, 2014 | 03:59 PM
I think I narrowed it back down to my IAC. I pulled the autozone duralast replacement that I bought and it appears that it may be defective. The little post seems like its loose and I cant seem to tighten it. I installed the original IAC and it runs a little bit better but still not great. Has anyone had any experience with the duralast IAC? Do I need to reset anything when I install a new one? I must be doing something wrong because this will be the 3rd IAC I have put on this car?
