Sponsored by: CARiD
High idle while rolling -sometimes
Old May 20, 2014 | 07:58 PM
nascarnate326's Avatar
Default High idle while rolling -sometimes
Sometimes my car will idle at a gauge indicated 1500-1800 rpm as I am coasting at 4 mph or at 40 mph.
Sometimes it drops back down to 1200 where it should. Typically does this after I have been on the gas real good.
I have replaced the iac, and tried the resistor mod for my air incoming temp sensor.
98 z28, 224 cam, tuned my mad tuner.
Why does my car behave perfect some days and horrible other days?
Old May 20, 2014 | 09:26 PM
inssanity21's Avatar
do you have a fast? mine was doing this and it was because the MAP sensor would come out enough to cause a vacuum leak and then come back in to be fine.
Old May 20, 2014 | 10:18 PM
Ported ls1 intake. I know, it was done in 2001 before fast was really a big brand.
I'll check it though.
Old May 20, 2014 | 10:45 PM
shep28's Avatar
I had that issue after my cam install and drilled a hole in my tb butterfly. Solved
Old May 21, 2014 | 05:21 AM
My car has a hole in the tb blade already. Anything else?
Old May 21, 2014 | 06:02 AM
SSdreamz's Avatar
subscribed...when you come to a complete stop does it settle down and idle perfectly?
Old May 21, 2014 | 07:08 AM
Yes. Usually takes about one or two seconds after I come to a stop and then it idles at 850(via OBDII port) like my tune says it should.
I have also replaced the entire PCV system so I am 100% positive there are no leaks or issues with that system.
Going to check the MAP sensor on the back of the intake tonight when I get home from work. Really sucks because I thought I had this care running perfect but it surges a little bit randomly and it does this goofy idle wile coasting or going slow. Some times its like a cruise control in second gear at 1800 rpm while going through a parking lot.
Old May 21, 2014 | 08:37 AM
demonspeed's Avatar
It's not mine! woo hoo!
Definitely sounds like a vacuum leak. Check the hose that runs from top of TB to passenger valve cover. I found that my throttle cable bracket bolt had rubbed a small hole and caused a leak in mine.
Also check the HVAC lines that pull vacuum from the back of the intake (they run behind the passenger strut tower).
Old May 21, 2014 | 09:08 AM
slow96ss's Avatar
I've been having the exact same problem for a while now but haven't had a chance to go digging for the problem. when I pull mine out of gear, idle jumps straight to 2k rpm and rubber bands between 1700-2000rpm till I come to a complete stop. Thinking mine is a vac leak though. hope your able to figure it out.
Old May 22, 2014 | 09:22 PM
Spink's Avatar
You've probably already done the idle relearn trick but if you haven't give that a shot. I had my battery disconnected and I had the same problem after I hooked it back up. Did that relearn and all is good. Mine does that every time I disconnect the battery for any extended period. I have a ported throttle body.
Old May 24, 2014 | 08:12 PM
I have no did it, care to share?
Replaced Throttle Position Sensor..no dice.
Went to pick up a pizza and it was doing its 1800 rpm cruise control/high idle, turned car off for maybe 45 seconds to go in and get the pizza. Came back out fired it up and it drove perfect all the way home.
What on the car could be so inconsistent?
Old May 25, 2014 | 08:11 AM
josephholtinsurance's Avatar
that sound like we have the same car. My car is doing everything you have described. I replaced the pcv hoses, IAC, TPS. Nothing has worked for me. The only difference is that man idles worst when o turn the AC on.
Old May 26, 2014 | 01:29 PM
Spink's Avatar
https://ls1tech.com/forums/general-m...e-relearn.html
Post # 14 works for me.
Usually I can just get away with doing the IAC relearn though. I'd try that first if you haven't tried that either.
Just unplug the three plugs going to the intake before the throttle body and turn the igition to run for 30 seconds without starting it while the plugs are all unplugged. Turn the key back to off and take it out of the ignition. Plug the plugs back in and start it. It may sputter a little at first but should smooth out. If it's not better do it again with the a/c turned on. If that doesn't work go to post #14 above.
In tyhe 9 years I've had my car I've probably had to do this 20 times and the IAC reset usually works 90% of the time. When it hasn't then post#14 worked the other 10% of the time.
If it doesn't work I think the others probably are right with the vacuum leak assessment. Start the engine when it's cold and get a can of carb cleaner and spray it around the intake and all the vacuum hoses. If the idle changes you've found your leak. Never seen it happen but if you spray the carb cleaner around on a hot engine it could possibly ignite so make sure engine is cold when you do that.
Old May 31, 2014 | 09:56 PM
Did Iac reset and it seemed to fix it for the most recent drive, Ill try it again tomorrow.
Old Jun 1, 2014 | 09:10 PM
Spink's Avatar
Cool. Once I went to the ported throttle body was when I had to start doing this and it always seems to work. Never have a problem until I disconnect the battery for awhile though then my idle does that same exact thing most of the time.
Old Jun 8, 2014 | 12:28 PM
Well the car is still doing it...very odd.
Seems like after I get off the highway it is fine..more of an in city issue.
Everything left to try is expensive, might have to live with it for a while unless someone has another idea.
Perhaps it really is in the tune, but I figured mad tuner would have his **** together.
Old Jun 15, 2014 | 10:41 PM
Spink's Avatar
One other thing you could possibly try is checking your coolant level if you haven't. Ive seen that screw with the idle on these cars more than once. Sometimes the simplest things can cause problems you'd never suspect. Worth a shot at this point.
Old Jun 15, 2014 | 10:47 PM
HioSSilver's Avatar
You can adjust your throttle cracker to control op's issue. I turned mine off.
another issue is the vacuum leak....except the leak is the extra area of throttle blade crack from the larger tb. I fixed mine by sealing it better with a small amount of epoxy around The throttle blade.
Old Jun 16, 2014 | 08:22 PM
What is the throttle cracker? Got a quick how to?
