Sponsored by: CARiD
trap door or drop the fuel tank
Old Aug 31, 2014 | 08:02 AM
Camaraderie's Avatar
Default trap door or drop the fuel tank
What have most of y'all done ?
Old Aug 31, 2014 | 08:31 AM
HCI2000SS's Avatar
Trap door for me. Much easier
Old Aug 31, 2014 | 08:48 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
https://ls1tech.com/forums/general-m...p-install.html
https://ls1tech.com/forums/general-m...k-removal.html
Old Aug 31, 2014 | 09:12 AM
ss performance's Avatar
To do it right you should drop the tank. With out a lift that is not the easiest think to do, that is why many people do the trap door.
The biggest problems with doing a trap door are,
1. not cutting to deep and damaging the tank, lines or wires
2. getting dirt and debris into the tank or seal area
3. coming up with a way of closing the hatch so it seals
If you can manage all these then you are in good shape.
One of the advantages of dropping the tank is being able to clean it out. It's amazing how much crap gets into the tank!
Good luck
Craig
Old Aug 31, 2014 | 10:53 AM
02DroptopZ's Avatar
I've done it both ways, and would never ever drop the tank again. The trap door is the way to go.
Old Aug 31, 2014 | 12:08 PM
Empatho's Avatar
I dropped the tank the first time, but the second time I did the trap door. I will never drop another tank on these cars again.
Old Aug 31, 2014 | 12:38 PM
notnilc20's Avatar
I did the trap door also. You must be very careful you don't cut any wires. I was careful and still cut one. But nothing a little solder won't take care of. To cover it back up i used some sheet metal and screws to hold it and then used foil tape to seal the edges. I have a mig welder but Something told me i better not weld right on top of the gas tank.
I'm glad i did the trap door method b/c if i ever need to get back in there it's only a few screws away.
Old Aug 31, 2014 | 06:00 PM
transwiz's Avatar
The trap door is the way to go.It is the easy way.
Old Aug 31, 2014 | 09:28 PM
Did y'all ever smell gas fumes ? With the trap door . I know people use gasket sealant
Old Aug 31, 2014 | 10:34 PM
_JB_'s Avatar
None here, and I had the trap door off for about 6 months.
Old Aug 31, 2014 | 11:37 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Definitely the trap door IMO, especially if you have the '98 and older metal tank (which seems to be harder to wiggle out than the plastic one - I've never tried to remove the plastic tank but I've heard it's easier).
The only way you would ever smell gas fumes from this is if you didn't get the pump sealed to the tank properly, in which case you'd also be getting an EVAP code. These cars have a fully sealed and highly monitored fuel vapor system, so if there is a leak anywhere (even pin hole) you'd get a code. If everything is installed and working correctly, there are no fumes outside the tank in the first place, and thus nothing to leak into the interior - trap door or not.
Having said that, I would still install a trap door simply to prevent dust/dirt, etc., from working it's way up with air movement, or to prevent any possible exhaust fumes from working their way up - especially if you have dumps under the axle. The foil/insulated repair tape is one nice way to seal the door, another would be rope caulk (more easily applied/removed than silicone). Of course, silicone/gasket sealant would work too.
Old Sep 1, 2014 | 11:55 PM
need4fun2469's Avatar
drop the tank. I have done it a couple of cars. Straight forward and easy
Old Sep 2, 2014 | 03:51 PM
dailydriver's Avatar
^^^THIS is one of the reasons I decided to drop the tank over hacking up the hatch floor.
Old Sep 2, 2014 | 03:55 PM
RockinWs6's Avatar
Trap door without a doubt. Dropping the tank is a huge pain in the azz. There is a filter on the pump and a fuel filter in the fuel line, no reason to clean out the tank at all.
Old Sep 15, 2014 | 01:13 AM
JakeFusion's Avatar
Super Hulk Smash
It took me about 45 mins to drop the tank. Once you unbolt the PH Bar, LCAs, and shocks, the axle falls right out of the way.
