replacing headlight motors - bumper or assembly?
which would be the easiest way to replace the headlight motors on a 2000 Trans Am?
1- Take the front bumper off to have easier access.
2- Take the headlight assembly off the car as a whole. (before I take it off, I would use a marking pen to outline where assembly goes to insure proper alignment when reassembling)
Thanks
Thanks
This is what I did, shroud only. Get a couple of 10mm stubby wrenches or one stubby one ratcheting and you're good to go. 30 minute fix, hardest part for me was getting the electrical connector seated back on the clip attached to the body, had to access this from the bottom.
