Sponsored by: CARiD
safe engine cleaning
Old Sep 16, 2014 | 10:47 PM
ltkill's Avatar
Default safe engine cleaning
So I'm rebuilding my engine but will be reusing the crank and pistons so my question is what can I soak them in to clean them with out damaging them they are out of a ls1
Attached Thumbnails safe engine cleaning-1410925863501.jpg   safe engine cleaning-20140913_161326.jpg
Old Sep 21, 2014 | 02:26 PM
Mercier's Avatar
I wouldn't soak the crank. A good wipe down with WD-40 and put it in a bag to protect from moisture until you get it back together. Crank shouldn't have any real deposits on it. If you really want to soak the pistons, carb/parts cleaner I think would be ok for your pistons I think..you can get the Berryman stuff at Autozone or O'Reilly in a paint can-sized container with a dip basket. Soak the pistons one at a time then clean them off. But you can usually just spray them down and wipe/scrub them with a rag. The top is usually what gets dirty.
