Sponsored by: CARiD
Mixed coolant question
Old Oct 23, 2014 | 09:40 PM
01Ws6ix's Avatar
Question Mixed coolant question
I was low on coolant when I was going to a car show a month ago and my buddy had me stop by his work and he topped it off. He works at jiffy lube and said that the stuff they use can be mixed with anything. It completely slipped my mind that my car uses dex cool and from what I've heard you're not suppose to mix it with anything. I scheduled a coolant flush tommorrow despite my friend saying it would be okay(he also owns a LS car), am I overreacting or should I go ahead and have it flushed? Need some advice thanks.
Old Oct 23, 2014 | 10:07 PM
im-not-guilty's Avatar
Their is a such thing as all makes or global coolant ...
It kind of a clear yellowish color ....
Your supposed to be able to mix it with any long life coolant
Old Oct 24, 2014 | 07:50 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Have it flushed and add a "water wetter product".
Old Oct 24, 2014 | 07:29 PM
RockinWs6's Avatar
You are fine, I use the same stuff all the time.
Old Oct 24, 2014 | 08:04 PM
wssix99's Avatar
Save the manuals!
Really interesting. I'd never heard of this before.
BTW - If you have a beer and read this thread with the word "coolant" deleted, it's kind of funny. ...but, I don't know how I know that...
Old Oct 25, 2014 | 02:22 AM
01WS6/tamu's Avatar
It will be a ok. But me being a nit pick I would flush it when you have time and refill with whatever your hearts content. I despise dexcool I run old time green antifreeze in everything and change it every 2 years and I've never had a LS engine problem since 98 using it.
But that's another argument for another time. You'll be fine put whatever you want to run in it s long as its fully flushed
Old Oct 25, 2014 | 02:45 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I would stick with Dexcool for an LS1, rather than mixing it IMO. I've used nothing else in my '98, and the entire cooling system is still 100% assembly line original and leak/issue free after 16 years. I do change it regularly though. Proper change intervals, not allowing large amounts of air in the system for prolonged periods (such as leaks), and using clean/distilled water for the 50/50 mix is all you need to prevent any problems with Dexcool in an LS application.
Old Oct 26, 2014 | 02:13 PM
dailydriver's Avatar
^^^I second the above!!
