Caliper removal = Brake bleed necessary?
Having a sort of debate with someone about this. If LS1 brake calipers are removed, is it necessary to bleed the brakes after? In other words, does removing the brake line from the caliper cause the brake pedal to go to the floor if you don't bleed them because air is now in the system? Or is it ok to just hook the lines back up as long as you don't let too much fluid drip out?
Thanks in advance for your thoughts/experiences
LS1Tech Premium Sponsor
Anytime the system is open to atmosphere in any kind of way it needs to be bled to ensure that all the air is out of the system.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I just did this replacing my pistons, and cleaning the calipers while they were taken off. The easiest method I found to bleed mine were just letting it gravity bleed itself. Took about 20 min. I watched it closely like the thread said and made sure the bowl stayed full. Not much fluid came out, but alot of air did.
