well this sucks
I still say.....an engine/tranny and its fluids as well as other fluids (brakes) need to be run through it and warmed up a little bit....and the car moves a little bit like a mile or two if possible.......every 30 days or so. FOR BEST RESULTS.
I know there's people that store cars for very long periods with no problems....well good for them......ALL CARS ARE NOT CREATED EQUAL. Some are just tighter than others.
....or....someone might have the keys to your storage and to your car...and are having a blast.........lol
I know your FL climate is different, but up here in the north we have periods where outside temps are stupid cold for sometimes an entire winter. This last February the average temp for the entire month was only 14°F. Under these conditions, you have to drive a car many miles to get even the coolant warmed up fully, and the oil takes even longer.
For 17 years my '98 Z28 has sat every winter, 4-6 months depending on how bad the season has been. I've said this many times before, but my daily driver '02 Z28 developed far more leaks/weeps/drips/etc. from being driven than the garage queen '98 has ever developed from sitting, even though the '02 was several years newer. It's a myth that limited use will cause [properly prepped] cars to fall apart at an accelerated rate during seasonal storage, as driving a car daily will cause just as much, or more, wear and deterioration over the years of heat cycling and general use.
As for the issue at hand:
1) I have the storage key
2) I and I alone know the passcode to get into the storage facility
3) I removed the battery
4) The impressions that the tires left on the Styrofoam were only 1 set, and the impressions were crisp, I would have known if they'd been moved or repositioned.
and I'm happy to say hopefully the temps next week ALL week, highs will be in upper 40s
so you all know what that meanscar is waking from its winter slumber next week. And then I will be investigating the trans leak.
Things age I guess. Hopefully it is just something stupid like the pan bolts are a little loose.
I'm guessing the OP's issue has to do with trans pan bolts, as the fluid had been changed just two days before storage and they often need a re-torque after a heat cycle or two. Or perhaps the bolts were over torqued already and have damaged the gasket, as this is not hard to do by accident.
I've never had a leak in this location with a 700-R4/4L60E though. But it's certainly true that as the converter drains back the fluid level will rise and if that tube seal is compromised it can definitely leak.
