Two problems: Keep getting low coolant and passenger valve cover always has oil
Old 04-07-2015, 09:01 AM
ShovelMan's Avatar
Default Two problems: Keep getting low coolant and passenger valve cover always has oil
I changed the once leaking water pump and replaced it with a new one. The new one doesn't leak but I am still getting low coolant. I bought some Dex-Cool and it just disappears from the radiator. I'm not sure how or why. The previous owner has already done the coolant bypass thing but I don't know if this can be the cause.
Also, the oil problem. My passenger side valve cover is always covered in oil. There's a hose that runs from the valve cover to the TB and when I check it, there's oil in it and in the TB. What can be causing this and how should I begin fixing this issue.
TLDR: Coolant and oil seem to be disappearing :/
Old 04-07-2015, 01:54 PM
Save the manuals!
wssix99's Avatar
It's probably time for a coolant pressure test before looking further for causes.
(A bad water pump can cause low coolant, but the new replacement would fix that.)
Old 04-07-2015, 04:50 PM
ShovelMan's Avatar
Hm, perhaps I will have to do that. There's times where I can smell the coolant coming through my vents inside my car.
Old 04-07-2015, 05:08 PM
MC Ray's Avatar
The oil issue sounds PCV related.
Quick Reply: Two problems: Keep getting low coolant and passenger valve cover always has oil
