Puddle of fuel on top of intake below rail.
Any ideas on what could be causing this?
Possibly the quick connect isn't fully sealing anymore at the fuel line / fuel rail connection. Possibly a cracked injector body, bad clip or upper o ring.
I can think of stuff but in the end you probable need to see it spray. Pull the ignition fuse so your assistant can't accidentally start the car. Or unplug the coil harness.
1. Depressurize the fuel rail and then remove the fuel rail and injectors as an assembly (4 bolts and the fuel disconnect, and the electrics)
2. Remove the metal clip holding the injector in place
3. Rotate the injector to free up the o-ring and then pull it out.
4. Silicone grease the o-ring on the new injector. Slide the clip onto the new injector from the side
5. Push the new injector into the rail, and the clip will snap into place.
6. grease up all the lower O-rings and reinstall the rail, connections, etc.
Typically, I'll remove the coils for more room and fewer scratches from the cowl
