Sponsored by: CARiD
temperature
Old Dec 1, 2015 | 12:04 PM
01ssreda4's Avatar
Originally Posted by RockinWs6
It averages the temp reading just like your fuel gauge works. Your fuel gauge doesn't jump around because its buffered to only show a average of the fuel level. Your temp gauge does the same thing.
Its not really like either of those. Its not buffered and it does not average. It simply doesnt move or respond to a certain range of temperature in its span. A fuel gauge buffers from fuel sloshing around. If the engine was -30 or -10 you wouldnt expect it to be readable on the gauge? That very well may be withing the sensor and computers capability but because the way the gauge is illustrated you expect to not read those tempsm what trips people up is that they designed another dead zone focused around normal operating temps.
Old Dec 2, 2015 | 08:42 AM
RockinWs6's Avatar
BS it reads just fine. YOU always try to start some kind of negative bs and honestly you don't know what you are talking about. I know EXACTLY how it works, right from the horses mouth.
If you know all about it then post up its logic! I'm calling you out on this one...PROVE IT or SU!
Old Dec 4, 2015 | 08:47 AM
01ssreda4's Avatar
Earlier cars got very decent gauge readings, proportional, equal gauge movement per temp increase with only dead zones for warm up. Example: gauges typically read what 140 on the low side, anything else under that it sits on 140 correct? You are aware the actual sensor range is likely in the negatives right? Have you ever looked at the PCMs programming? The sensor will read down past freezing and the computer can see that. It is very obviously engineered to not read that low cause its not important to deviate between 80 and 130 degrees. The reason is because the engine is under temp and running in open loop fueling in both circumstances, so its not necessary to differentiate between the two. Same would go for max temp, the gauge will likely be pegged whether the temp is 250 or 295. So between x temp and x temp the gauge used to move evenly but in the extreme lows and highs it was still. That was a full mechanical gauge. Now a days since the computer controls the gauge (98 was the last year of the mechanical temperature gauge) on every car being manufacturered they have engineered a dead zone. The sending unit DOES read actual temp ( read as ohms by the pcm) but the pcm output to the gauge slows during normal operating temp. If the engineers decide the vehicle will spend most of its time between say 185 (stat opening) and 230 (just above high fan speed setting) then when the car gets to the low end they will have the gauge more or less freeze and not resume upward movement until actual temp crests 230. The sending unit is always telling the ecm actual engine temp, but proportional movement of the needle is not taking place in that dead zone because its engineered into the gauge or pcm to act that way. Get a scan tool and see for yourself. Then slap yourself for acting butthurt. And hey, maybe we are saying the same thing just saying it different ways.
Old Dec 4, 2015 | 09:20 AM
RockinWs6's Avatar
BS you know nothing about it.....
Old Dec 4, 2015 | 09:22 AM
Mappinsj's Avatar
ssreda. Obviously your car is not fast. It can't even do a wheelie. So obviously you know nothing.
Old Dec 4, 2015 | 09:24 AM
01ssreda4's Avatar
And someone has a history of getting butthurt
https://ls1tech.com/forums/general-l...l#post19036101
Lmao, but your posts are quite entertaining. When I get a break im gonna read more of them.
Old Dec 4, 2015 | 12:14 PM
01ssreda4's Avatar
And there it is.....you still holding onto this? I knew I remembered youre name. Let it go man, its gonna be alright.
https://ls1tech.com/forums/gears-axl...so-weak-2.html
