Ignition lock cylinder
my question is that will the new one need to be programmed to the VIN and or will it mess with the VATS system..
keep in mind that ever since I have had the car the Security light has been on with no ill effects so far..
Bypass vats, take your current key to Home Depot or wherever and make a copy and be done with it. Unless you are dead set on a OEM key with working vats chip then the way you said above will work too.
