Sponsored by: CARiD
Symptoms of air in coolant?
Old Dec 18, 2015 | 04:32 PM
Garrett Shaver's Avatar
Default Symptoms of air in coolant?
Just rebuilt my 5.3 in my Silverado and and it's acting weird I've replaced the thermostat twice and it's still overheating and the heat is working off and on I've filled the radiator and the resivior and the hoses aren't getting hot everywhere and the heater hose lines are pulsing (not steadily flowing) could it be the water pump shaft spinning on the impeller? Or Just air in the system? And how can I bleed the air?
Old Dec 18, 2015 | 05:49 PM
LS6427's Avatar
If your water pump shaft sheared off no coolant would move ever and you would go right into the red on your temp gauge. Its like 1 in a million that a shaft shears.
Take the t-stat housing off and remove the t-stat from the housing....then put the housing back on, just snug it back on with one bolt. Leave the radiator cap off so no pressure builds up and start the engine. Keep filling up the radiator till its topped off. When it won't take anymore water/coolant......it is 100% full and you have zero air in the system.
Turn on the heat and see if blows hot...it should because there's no air in there anymore.
Now you can be sure the system is fine and that you probably did have some air in there somewhere.
Now put the t-stat back in and tighten it down with both bolts. Of course you will lose some water/coolant by putting the t-stat back in......... Top off the coolant, Start it back up and let it idle till you see the coolant start to flow in the radiator cap. When the level drops...IMMEDIATELY start topping it off. Wait one more time for the t-stat to open again and you see the flow....then top off again if the level drops. If the level did drop down again.....do it a third time.....and so on....till the level stays full as coolant starts flow.
Done. Put the cap on and go.
Old Dec 19, 2015 | 12:49 AM
Thank you I got It worked out
