Tach shuts down while driving
other possibility is having bad wiring some where, while car is running vibration could be causing a bad connection or short causing an intermittent problem... or you might have a PCM going bad, or the stepper motor in the cluster that moves the rpm needle is going bad... not knowing history of car i can only speculate and the above is based on an unmodified car that's been taken care of but is also 10+ years old.
I was just expecting too much at idle from the alternator. Investigating buying a smaller pulley, to keep RPMs up at lower engine speeds.
