window regulator
Is this the problem that you are having? https://ls1tech.com/forums/general-m...-included.html (If so, you'll need more than new rivets to fix the issue...)
$15 of the wrong rivets - or using a bolt instead of a rivet can cost you a $300 door. ... plus painting.
