Sponsored by: CARiD
Ac leaking
Old Oct 8, 2016 | 03:16 PM
z28pat's Avatar
Default Ac leaking
I was driving and my air started blowing very slowly even on max setting , the air was cool but barely coming out of the vents.
I turned off and back on and then back on and it worked for a bit and then same thing, it started barely blowing.
When I got home I parked the car and a it leaked out a puddle of cold water from the passenger side of the car.
Any clues as to what that could be?
Bad compressor, freon leak?
Thank you
Old Oct 9, 2016 | 11:05 PM
RockinWs6's Avatar
Evaporator froze over, air flow is blocked , turn off ac car and it defrosts and water puddle results. You are probably low on AC coolant r134A, with your limited knowledge you should find a trustworthy wrench to check the AC charge. Low change can cause the evaporator to freeze over.
Old Oct 10, 2016 | 12:51 PM
z28pat's Avatar
Thank you ! The ac system is not my forte so I appreciate the knowledge
Old Oct 10, 2016 | 02:21 PM
Spartan7's Avatar
I doubt it's that, but it's easy enough to test. Turn it to heat (or just not on A/C) and see if the lack of airflow persists. I'd suspect the blower motor, because that's what actually moves the air around.
