last coil pack bracket bolt (valve cover gasket)
Trying to change valve cover gasket on driver side and I can not get to the last top bolt because of that bracket that sits on top NEED HELP ASAP
Super Hulk Smash
Did you pull the coil bracket off? Remove the coil bracket and then you can get to the valve covers easily. You can just rest it on the exhaust manifold/header and not unplug any of the plug wires. That's the easiest way to do it. The driver side bolts are easier to get to than the passenger side bolts, btw, so be glad it's the drivers side.
