Blower motor/ac vent problems
I read that the vent doors inside the bottom of the system to direct air flow were controled by vacume. So what do you guys think I need to do to fix this problem. I am kinda stumped.
The port points 90 degrees to the ground....straight towards the passengers side.
http://my.prostreetonline.com/wp-con...MAP_sensor.jpg
So I am guessing that there is a vacume leak somewhere. If I pull the hose off that t coupler that goes to the firewall it should have some vacume in the line. Can I get some flexibale tubing and re-run it from the back of the intake manifold?
Is the T-Fitting cracked, they get briddle and crack sometimes and they are little fine cracks around it that sometimes go over-looked.
Sweet.......
