Sponsored by: CARiD
Ls1 idle issue and misfire
Old Jan 5, 2017 | 07:09 PM
TheWarHawk's Avatar
Default Ls1 idle issue and misfire
Hey guys I am new to the forums and I don't think this is the right area to post it but I can't access the general maintenance forum.
I have a 1999 ls1 Trans am auto, it is about stock excluding air filter and slp LM1 exhaust and cat delete.(I have had this issue before the exhaust install and cat delete) It was a garage kept vehicle when I bought it and I continue to keep it covered and clean.
I am suffering from a rough idle issue and a misfire I can feel at about 1500 rpms. I get the bank 1 and 2 codes and a p0300 code on my obd2. when accelerating it is very smooth and no loss of power, My car starts instantly and idles very good until it is up to optimal engine temp then I notice the rough idle. sometimes I have slight hesitation accelerating at a dead stop when it is idling terrible. I am not sure what could be the problem.
I have checked for vacuum leaks, I have replaced plugs and wires, replaced both upstream o2 sensors(the codes have returned after replacing them), I have ran a seafoam treatment and changed the oil, I have cleaned the MAF and air filter too.
Any ideas or suggestions? Thank you for reading-Travis
Old Jan 5, 2017 | 07:37 PM
navyblue_02's Avatar
When your car is running, wiggle each of your injector clips. If your idle improves, make note of which one, double check your connection, and get a replacement injector pigtail if necessary, Good luck!
Old Jan 5, 2017 | 10:26 PM
TheWarHawk's Avatar
Thank you Navy, I will try this.
Old Jan 5, 2017 | 10:31 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
What do you mean by this? Which bank 1 and 2 codes? There are several codes that are listed by bank, which ones specifically are you seeing?
Old Jan 11, 2017 | 04:19 PM
RockinWs6's Avatar
Check the intake bolts, I would back them all off a full turn and torque them to 89 INCH lbs.
Old Jan 11, 2017 | 07:39 PM
LS6427's Avatar
And if you list a code number.......ALSO list its complete description so we don't have to go look them up.
