filters and oil
Thanks
Bottom line: The differences are marginal for most applications, so unless you're at the extreme end of operational parameters you should be fine with any quality oil and filter.
Nothing magical about OEM products. I would think the AC/Delco filters are rebrands made by other manufactures. Napa Gold/Wix, Fram ultra guard, M1 are all great filters. I use M1 0w-40 (12.9 cSt) and buy the Fram Ultra Guards because I can find them at half the price ($6) of the M1. And with mfg rebates you can buy M1 by the 5 qt jug for $12-$13 during the year (same for PP/QSUD). If you want to read a ton on the subject go to Bobistheoilguy.com. You'll be buried in choices.
Any name brand/SN synthetic should do. Everyone has their preferences. Mine would be Pennzoil Plat or Ultra, Mobil 1, Castrol Edge, and even Synpower. If you live in a warmer climate with mild winters you might even consider a 0/5w-40 in any of those above brands. The major differences between them are the add packs which can run from high calcium-no mag-no sodium oils, lower calcium - high magnesium, and moderate calcium - high sodium. I prefer the high calcium which comes with PP/M1/Synpower MST 0w-40's. The Castrol Edge reformulated their 20/30 grades to high calcium but left their 0w-40 at lower calcium - high magnesium. Synpower or NAPA in the 20/30 grades is a sodium oil. In 0w-40 most of them certify at A3/B4 standards meant for top Euro standards....not many of the 5w-30 oils certify to that level. GM only requires Dexos 1 which most 5w-30 A1/B1 synthetics meet.
If anyone considers M1 5w-30 as weak/over-rated, I would submit that QSUS/PP 5w-30 are probably even weaker, their op viscosities certainly are. M1 does offer some stouter 5w-30's such as their HM variant. And M1 10w-30 is even stouter and A3/B3. If I lived in a warmer winter climate I'd probably run that instead of the 0w-40 if only to reduce shear and stay in a strong 30 grade (12.1 cSt).
