Sponsored by: CARiD
Know this tick/tink sound?
Old Mar 31, 2017 | 05:15 PM
Davy Bass's Avatar
Default Know this tick/tink sound?
Hi guys, trying to search for this but when I search keywords, I just get "lifter tick" or rhythmic ticking of sorts.
​​​2000 trans am a4. When I hold the brake and shift from neutral to drive, I hear a couple of slight tick sounds. Not clunks. The harder I push it, the more it makes until it has enough pressure that it's stopped. It almost sounds like a gear slips I couple thousandths and makes the tick sound.
It also happened on my 1998 camaro ss a4. I never had any problems besides the sound
Actually I just found a video of my camaro making the sound
Ideas?
Old Apr 1, 2017 | 02:05 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Do you have an aluminum driveshaft in your '00 Trans Am? If the car was optioned with 3.23s (GU5) then it would have come stock with an aluminum shaft. Your '98 SS definitely came with an aluminum shaft as 3.23s were a required option for SS (WU8) with an A4 (MX0/M30) trans.
If so, then what you're probably hearing is a somewhat common occurrence, often referred to as "driveshaft tink". Some are worse than others, there were more reports of this when these cars were newer and still getting fixed under warranty. Some were so bad that they would make this noise even during a normal upshift at cruising speeds (my '99 was like this.) Others only do it when shifting into gear or sometimes when power braking. GM had a couple different stories for the source of the problem, but ultimately I think it had something to do with the welds on the DS ends. DS replacement was usually the only cure.
Steel driveshaft cars didn't have this problem, it was specific to the aluminum shaft. Interestingly, the M6 cars rarely had this issue even though they all came stock with an aluminum shaft.
Old Apr 1, 2017 | 09:11 AM
Davy Bass's Avatar
Interesting. That's almost certainly what it is. I'll check the driveshaft but I'm pretty sure it's aluminum. Like you said, the ss did have aluminum. It does sound like a little ping on hollow aluminum.
Any idea if the driveshaft will actually break under normal conditions? Worst abuse I'll give it is a low speed/stopped powerbrake for some smokey fun from time to time
Old Apr 1, 2017 | 11:08 AM
RPM WS6's Avatar
I've seen the stock aluminum shafts rip open like Coke cans on a few M6 cars that were launched hard on sticky tires (or sometimes with a really hard shift to 2nd on said sticky tires) but, again, those manual cars rarely made the "tink" to begin with - can't say that I've ever seen an A4 example rip like that, regardless of tinking factor.
FWIW, my '99 car did this horribly, the shaft had to be replaced under warranty but it never broke apart. My '00 car also had an A4/aluminum shaft, and it would only tink when shifting into gear or occasionally when loading the torque converter prior to a launch. Never enough to bother me, nowhere near as bad as the '99. I drove it like that for years, cut 1.6 60-foot times on sticky DRs and the noise never got any worse nor led to any additional problems or DS breakage.
Old Apr 5, 2017 | 10:32 AM
Docrocket1967's Avatar
I have no sound but if it is the sound I think you are explaining it's a very common thing for the 4th gens. A buddy of mines, 99 SS does it real bad. Ive read where some guys have replaced u-joints and it went away and some guys had to replace entire driveshafts to remove the noise. Could be your torque arm is loose too. just my 2 cents
Old Apr 5, 2017 | 11:24 AM
Davy Bass's Avatar
thanks for the tip. the more I research, the more it points to driveshaft tink that everybody's talking about. if I do a brake stand and slowly give it enough pressure to where it just barely starts to spin the back tires, within that 3-4 second window, it will tink 3-5 times or so. sometimes it will even tink when driving normally when it shifts from 1st to 2nd. I think I'll just leave it for now and keep an eye peeled for a good deal on a replacement shaft that I can test before committing to buy.
Old Aug 1, 2017 | 07:31 PM
wannafbody's Avatar
I have a tink over bumps, wonder if this is the cause?
Old Aug 2, 2017 | 12:43 AM
RPM WS6's Avatar
No, if it's only over bumps then it's not the DS issue discussed in this thread.
