Sponsored by: CARiD
A/C idler pulley
Old Apr 17, 2017 | 06:27 PM
TAvsGN's Avatar
Default A/C idler pulley
Changing out pulleys on my 98 T/A. Got the A/C belt tensioner out and moved to the idler pulley. I was actually able to get the torx bolt out with no problem (will be replacing that bolt though that I found during a search). What I couldn't find during a search is if the idler pulley is pressed on the bracket. Didn't work on it long, but it will not budge after removing bolt. Any advice?
Old Apr 17, 2017 | 08:01 PM
TAvsGN's Avatar
Nevermind. Went out after dinner and worked on it somemore. It came off with a little work. It was just kinda corroded on the bracket.
