Sponsored by: CARiD
turn signal switch
Old Apr 10, 2017 | 11:57 PM
Lt1slowerbird's Avatar
Default turn signal switch
Wipers work, blinkers work, only issue is I can't turn on my high beams, it won't click. Sometimes if I put left blinker on I can get it to click, also ifbl I smack it back quick it will turn on high beams, what all do I need to replace? The turn signal switch or the combo switch thing? Also any write-ups would be appreciated
2000 trans am
After taking off the little cover and seeing the headlight switch, if I pressed on it and held it to the steering column the headlights clicked on and off fine but when I let go the headlight switch moves just enough that it can't click. Any thoughts?
Old Apr 11, 2017 | 12:53 AM
chrysler kid's Avatar
The high beam switch can get loose and wiggle it's way down the steering shaft. I used a zip tie to pull it back up towards the steering wheel so the high beams would click again
Also related when that switch couldn't touch the high beam metal rod my cruise control wouldnt work. Once I got the high beam switch to work the cruise worked again
Old Apr 11, 2017 | 01:05 AM
Need4Camaro's Avatar
Also related when that switch couldn't touch the high beam metal rod my cruise control would work. Once I got the high beam switch to work the cruise worked again
Mine is doing the same thing as the OP's. Did you have to take apart the entire steering column to fix this?
Old Apr 11, 2017 | 06:31 AM
Mine works with pressure not towards the wheel itself but towards the steering column. Imnnot sure what to do or try. I'd hate to have a black ziptie running around my steering column
Old Apr 11, 2017 | 07:20 AM
wssix99's Avatar
Save the manuals!
FYI - It sounds like you are working with the wiper switch, which is the device behind the small cover that the turn signal stalk sockets directly into.
That stalk and wiper switch activate a rod that runs down the steering column. The rod intersects the actual high beam switch, which is attached to the base of the steering column behind the panels under the dash.
Old Apr 11, 2017 | 07:34 AM
If you look at what the rod connects into behind that there is a rod thing that moves in and out when you try to activate headlights. I'll try to get a picture.
Old Apr 11, 2017 | 07:40 AM
No, you just need to take off the lower dash panels to look up into the column areas
Along the left side of the colum, try to engage the high beams and you should see a metal rod moving. Follow the rod down to the switch and feel where it is suppose to sit in the switch. It should be tight and sitting in the switch. If it is loosely in the switch it will cause the high beams not to engage
Getting to the bolts is trucky, I think they are a 7mm bolt at the front and rear of the switch. If your lucky you can slide the switch by hand to pull it up towards the column. There is a hole on the switch not used that I looped a zip tie to in order to pull it up on the column
I think this picture is with the column support bar under the dash loose
View from under the dash looking up
Old Apr 11, 2017 | 12:20 PM
I have no idea how to get to the bolts. Getting pretty angry lol
Old Apr 11, 2017 | 12:46 PM
In the picture from the bottom, you can see two metal braces. The big lower one is basically a crash cage, the higher small one holds the colum up. Those braces shouldn't be too difficult to come off and it will lower the column for easier acess
Old Apr 17, 2017 | 11:46 AM
So I think I understand it now, the turn signal stalk is attached to a lever, when you pull the stalk it pushes the lever into the highbeam switch and engages / disengages the beams..and as suspected mine doesn't look to be fully contacting. How do I pull it back up? Here I made a video of what its doing...
Old Apr 17, 2017 | 02:42 PM
wssix99's Avatar
Save the manuals!
My recollection is that the switch at the end of the rod is where the "click" comes from. So, if it isn't working when you press it by hand and you aren't getting the "click", then that switch may just be bad.
Old Apr 17, 2017 | 06:29 PM
https://www.youtube.com/watch?v=zzTpLJSamjo
It's not like I didn't just describe how to do that in every response in this thread
Old Apr 17, 2017 | 08:19 PM
It seems to click when I push it by hand, just not with the lever.
Mine doesn't appear to be loose enough where I can wiggle it back up so I wanted to make sure that those two 7mm bolts you described would need to be loosened and then the mechanism would need to be slid up the column and then retighten the bolts..is that right?
Old Apr 18, 2017 | 10:16 AM
Yeah.
There is a little slack in the rod itself so it should always contact the switch, if the switch moves too far away the lever cant push the rod down far enough to get the switch to click
You have to loosen the 3 bolts and slide the switch slightly higher up on the column
