Sponsored by: CARiD
Faulty Coolant Temp Sensor?
Old Apr 20, 2017 | 09:33 AM
Crimsonnaire's Avatar
Default Faulty Coolant Temp Sensor?
Hey, everyone.
Lately, I've been having erratic coolant temperature readings on the gauge from time to time, where the needle would drift back and forth while the engine's working its way to full operating temp, where the engine's idling RPM becomes unsteady while this happens. In addition, the needle would less commonly jump upwards to as high as the third quarter mark all of a sudden, activating the radiator fans and then quickly falling back to the middle in less than a minute. So my question is, can a faulty coolant sensor in an LS1 erratically give higher than actual temperature readings or does the mechanism of the temp sensor's function necessarily confine it to give only lower than actual temperature readings when malfunctioning?
Can someone also tell me where the sensor's located?
Thanks very much.
Old Apr 20, 2017 | 12:12 PM
chrysler kid's Avatar
It's above spark plug #1 in the cylinder head
Yes, I would replace that sensor. If your car is a 1998 it will require the specific 3 pin sensor
Old Apr 20, 2017 | 06:25 PM
Majestic9C1's Avatar
when you change it have the replacement real handy because coolant will start coming out as soon as you take it out...
Old Apr 21, 2017 | 11:27 AM
LS6427's Avatar
Engine idle can be affected in some cars. My 1998 runs horrible with a failed or unplugged temp sensor. It idles so bad it backfires and wants to stall.
Thats why I keep a spare in my car.
Old Apr 23, 2017 | 10:49 PM
Need4Camaro's Avatar
Mine won't even crank if the temperature sensor is bad, or unplugged.
Old Apr 28, 2017 | 10:18 AM
LS6427's Avatar
I hear you.
I've been telling people for a long time....all PCMs are not the same. I have many friends who's cars run perfect without the coolant temp sensor plugged in or broken off with the sensor still in the head. Some run ok, some will run really really bad like mine.
And now yours.....won't even start.
Its all up to the PCM......
Old May 5, 2017 | 07:54 AM
When mine was bad I had to disconnect it. It would run in limp mode and often be hard to start. Also the fans would run constantly even for a few minutes after the car turned off
