Sponsored by: CARiD
2002 power steering problem
Old May 11, 2017 | 06:09 PM
johnfin's Avatar
Default 2002 power steering problem
A few months ago I noticed a leak at the side hose that goes to the cooler a while back and I bought a new hose and clamps. Power steering was making noise so I took the filler cap off and there was a ton of pressure. Thats why its blowing off the side hose. What is causing this?
2002 ss camaro
Old May 12, 2017 | 08:40 PM
Z28 6spd's Avatar
How did the PS fluid look and was the level correct? These cars with factory PS coolers are notorious for failure and allowing coolant and power steering to mix. Maybe the cause of the excessive pressure you have?
Plenty of info here - https://ls1tech.com/forums/general-m...g-success.html
Old May 13, 2017 | 04:06 PM
johnfin's Avatar
Default Oil
Empty
Old May 14, 2017 | 08:04 AM
LS6427's Avatar
Originally Posted by johnfin
Empty
Remove that horrible factory power steering cooler.....get a full length rubber hose.
Then for about $40 buy a 4 fin aftermarket cooler and run the two cooler lines to it. Done.
BUT....if in fact the factory cooler did spring a leak...you will need a full flush of all PS fluid first. Perfect time to do the aftermarket cooler. You will also need to do a complete coolant system flush.....there's gonna be PS fluid in there.
Here's mine....and it really does take only 15 minutes.
https://ls1tech.com/forums/general-m...l#post14186846
If you need a complete instruction write-up from start to finish....let me know.
Old May 14, 2017 | 02:53 PM
johnfin's Avatar
Coolant is not leaking, the power steering pump has pressure and is pushing the fluid out of the return hose.
Old May 15, 2017 | 07:25 AM
steering_experts1's Avatar
2002 ss camaro
Which hose are you having problems with: the hose from the rack to the cooler, or the hose from the cooler to the reservoir?
The reservoir is designed to hold some pressure, approximately 7.5psi. This pressure is caused from fluid expansion when the fluid heats up. This is normal for this system, and may be misleading you to believe that it is the cause of your hose leak.
Thanks,
Jeff
Old May 15, 2017 | 11:15 AM
johnfin's Avatar
Default Cap
I tried a cap off my transam and it seems to have fixed the problem so far. Dealer replaced the pump prior to me getting the car, boy were they dumb.
Old May 16, 2017 | 03:42 AM
LS6427's Avatar
Remove that factory PS fluid cooler as as possible.....it will fail.
Old May 17, 2017 | 11:30 AM
johnfin's Avatar
Default Cooling
Some questions an comments:
1. Read your article, its old and links dont work
2. Not sure about that placement. Finned heat exchanger likes flow
3. If the standard v8 car bypasses the cooler, is the ps pump different?
4. What about a hyden cooler in front of condenser
Old May 17, 2017 | 10:37 PM
chrysler kid's Avatar
Empty
