Sponsored by: CARiD
Summer. Time for AC questions
Old May 17, 2017 | 06:43 AM
farmington's Avatar
Default Summer. Time for AC questions
my AC hasn't worked since my cam install about 5 years ago. Believe it was somewhat taken apart but not fixed correctly but it did work prior to that. Would like to get it going again. What will I need? Dryer? Assuming a vac out and pressure test and refill. Anything else?
Old May 17, 2017 | 10:33 PM
chrysler kid's Avatar
Replace drier and replace drier o rings.
Assuming the system has remained sealed and not exposed the compressor to the elements you can replace the drier and evac the system.
Buy the freon from Walmart.
Old May 17, 2017 | 11:48 PM
Crashz28's Avatar
If it was open or has zero pressure replace the drier pull a vacunm if it wont hold a vacunm you have a leak still if it does then refil and hope the seals in the compressor hold up.
Old May 18, 2017 | 06:28 AM
farmington's Avatar
Thanks. Can I replace the dryer then take it to a shop to be vacuumed and leak checked ?
Old May 18, 2017 | 12:18 PM
Crashz28's Avatar
You should be able to. Might have to go to a few different shops but im sure theres a shop that will do it
