Oil Change Intervals
I have ten 5 quart jugs of magnatec 5w30 and 10w30 I picked up from autozone for $10 a jug, and 3 cases of vr1 I got for $1 a quart clearance at autozone.
I know alot of people who buy parts online, but when you know a guy on the parts counter he will give you a call to sell some bulk oil lol
I personally couldn't ever not run synthetic. I've had my used f13 camshaft in the car for 60k miles and never touched the bottom end. 140k miles on my 98 which is known to have the worsst oil drain block design and weakest main caps
https://www.walmart.com/ip/SuperTech...Quart/16565378
Furthermore... intervals and synthetic ramblings are comical.... It's all how how you use the car.
I know ppl changing their synthetic oil each week... because they flog the car at the road course 2-3 days/week.
Then my dad changes his once a yr... since he's only driven 10k mi in the matter of 15 yrs. Yea, it's synthetic... Cheap insurance. More stable.
I just change mine every 3k. Lucky to get 4k on my car a yr. Yea, it's synthetic... Cheap insurance. More stable.
Our daily cars only take synthetic because that's the only way 0w20 is available. 10k mi factory intervals too.
My friend has numerous cars over 200k mi... just uses conventional oils in them. Works for him. My way works for me. Whatever makes you happy.
I change my T/A oil around the same intervals ( 2500-3000) and around 5000 on my daily driver's. I also run diesel oil in my vehicles ( rotella t6 )
There's the promotions/rebate thread running on BITOG that gets you $2.65/qt for a name brand synthetic oil during the year (PennzPlat, SynPower, Castrol Edge, M1, QSUD). And here's the exact thread for the SOPUS (PP/QSUD/QSAD) rebates. Ignore some of the bitching on those that claimed they got screwed out of rebates. If you don't want to take 10 minutes to submit a rebate, then just wait until the December AutoZone clearances and buy top synthetics at $2/qt. In 2015 they actually went down to $1/qt. Some stores aren't as good as others. But most people have multiple AZ's in their area, especially near larger cities. One of these years though, AZ is going to get smarter and stop doing this.
https://bobistheoilguy.com/forums/ub...es#Post4292706
I will say once again, if you're living in the continental US and have a Walmart anywhere near you, then getting Mobil 1 or Pennzoil Plat at a net $12-$14/5 qt jug is the NORM that past couple of years. Other retailers besides Walmart often have discounts too. Read through the above BITOG thread. No Walmart close enough to drive to? Then order it on line, order over $50 worth of oil (2 jugs+) to get free shipping and have them deliver it to your home. Then process the rebates. SOPUS allows up to 24 qts or $48 in total rebates. M1 has a $24 rebate limit per household.
Walmart PP and M1 jugs are typically at Walmart for $22-$26. I usually wait until they are on roll back at $22. In fact during this past Thanksgiving weekend Walmart had Pennzoil Plat on roll back at $19+....with a $10 rebate that was under $10 per jug. The shelves cleared out in short order too. Subtract the $10/$12 mfg rebates from $22-$26 and you're in for $12-$14 per jug. I've bought 6 jugs the past 2 years with rebates, never higher than a net $2.67/qt. The other $10 jugs of Castrol Edge 0w-40 I got during the Autozone clearance sale in December. At that same time I picked up a load of PP/Synpower in 30/40 grades for $2/qt. Spread your wings and look around.
If anyone near me (zip 06371) wants Castrol Edge 0w-40 jugs at my cost ($11 each) I'd be happy to oblige. I have about 15 qts of PP Euro 5w-40 and PU SRT 0w-40 be happy to exchange for $2/qt. I have too much of it any ways. And can always buy more. The Pennzoil rebates run during all of 2016.....and will run all of 2017 as well. The Mobil 1 rebates run 2X per year. The current one for $12/jug ends in May. If you can't get $2.65/qt oil, you aren't looking for it.
There's the promotions/rebate thread running on BITOG that gets you $2.60/qt top synthetic oils during the year.
I will say once again, if you're living in the continental US and have a Walmart anywhere near you, then getting Mobil 1 or Pennzoil Plat at a net $12-$14/5 qt jug is the NORM that past couple of years. Other retailers besides Walmart often have discounts too. Read through the above thread.
Walmart PP and M1 jugs are typically at Walmart for $22-$26. Subtract the $10/$12 mfg rebates and you're in for $12-$14 per jug. I've bought 6 jugs the past 2 years with rebates. The other $10 jugs of Castrol Edge 0w-40 I got during the Autozone clearance sale in December. At that same time I picked up a load of PP/Synpower in 30/40 grades for $2/qt. Spread your wings and look around. I'm not going to buy the oil for you and process your rebates too....lol.
If anyone near me (zip 06371) wants Castrol Edge 0w-40 jugs at my cost ($11 each) I'd be happy to oblige. I have about 15 qts of PP Euro 5w-40 and PU SRT 0w-40 be happy to exchange for $2/qt. I have too much of it any ways. And can always buy more. The Pennzoil rebates run during all of 2017. The Mobil 1 rebates run 2X per year. The current one for $12/jug ends in May. If you can't get $2.65/qt oil, you aren't looking for it.
What is the Pennzoil Platinum Euro?
Don't be confused with a Penn Plat Euro L version. That's a low SAPS version oil as I recall and probably is not A3/B4 certified...meant more for diesels. The Pennz Plat Euro 5W-40 is a stronger oil than than similar graded PP oils. Mobil 1 0w-40 FS is also a Euro blend with similar A3/B4 approvals....though in this latest variant, M1 lost the BMW LL-01 cert. In a nutshell, the M1 0w-40 "FS" dropped a bit closer in viscosity to a regular M1 5w-30 grade oil. They still sell the earlier (pre-Feb 2016) and "thicker" M1 0w-40 variant in Europe....still meeting all the Euro mfg specs. Regardless, I still use the M1 0w-40 FS in my LS1. Since the car actually calls for a 5w-30, getting a little lower in viscosity is probably a better idea for how I drive. The "FS" version barely starts off above the highest viscosity that a 30 grade oil allows (12.5 cSt at 100C). It will shear down into a 30 grade within a few thousand miles.
Just got done with a h/c build and did my season beginning oil change after the install and Walmart was out of rotella t6 so I ran the Pennzoil Platinum Euro 5-40
Pretty sure the guys at Jasper that are designing their own in house pistons for these engines are engineers, next time my rep is in here I'll get the list and PDF info.
Newer Toyota, BMW, Lexus, VW, etc all have oil change intervals of 10k or more.
I think a lot of people get in trouble when they hear one thing on the street relating to one of those flavors and try to apply it as a blanket to everything.
That's kind of shocking considering how they bend their customers over the barrel for service!
Great point - I wonder how many average drivers take the time to understand this and learn how to reset it?
The vast majority don't I bet, the sales guys probably quickly glance over that and say the car will tell you when it needs anything, now lets sync your phone to the bluetooth hands free system...
as i was draining my oil, it still looked brand new. But i usually change my oil 2x a year. I use M1 5w-30.
