Sponsored by: CARiD
Question for those who know
Old May 21, 2017 | 07:11 AM
Mezzy's Avatar
Default Question for those who know
Hi guys,
​​​​​​My question is this. After welding in my Sub frame connectors, I was told I may want to change the body bushings so the frame doesn't crack from absorbing vibrations over time. Is their any truth to this?
Old May 21, 2017 | 10:13 AM
Orange Juice's Avatar
Never heard of that.
Old May 21, 2017 | 11:31 AM
01ssreda4's Avatar
There are no body bushings.
Old May 21, 2017 | 12:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
To the OP: Whoever installed your SFCs clearly wasn't paying much attention under the car, and/or doesn't know much about 4th gen F-bodies. There are no such bushings to change in this application.
Old May 26, 2017 | 01:05 AM
eb110americana's Avatar
If you bother changing the body bushings, you might as well top off the blinker fluid and swap out the muffler bearings while you're down there.
Old May 26, 2017 | 12:04 PM
joecar's Avatar
and make sure your flat washer is tuned and gapped correctly
Old May 26, 2017 | 03:02 PM
RockinWs6's Avatar
Don't forget to tighten the loose nut behind the wheel too.
Old May 26, 2017 | 03:48 PM
LLave's Avatar
Probably want to change out the air in the tires from winter air to summer air.
