70mph+ Vibration unsolved
I've done a lot of reading from previous threads on this issue, and so far nothing checks out.
First, explanation of the vibration; Approximately above 70mph+ the car begins to vibrate internally. I wouldn't call it severe, but it's pretty annoying. It is mostly noticeable on the steering wheel, shifter, and the door panels. It occurs in any gear, not just 5th or 6th and neutral (theoretically ruling out the transmission) It's not intolerable for driving, but I wouldn't want to take it more than an hour away due to the pure annoyance.
What's been done. (Car was lowered)
Wheels/Tires balanced, and re-balanced again to double check.
Adj. LCA's, Adj. Panhard, Subframe connectors, Adj. Torque Arm.
We have the driveline angle set to -2* from the crank pulley to the axle, which is the last advice I read on here somewhere. At this point, the next thought is maybe the driveshaft, but I'm at a loss currently.
Thoughts?
I had a vibration that would start at about 50mph and not go away all the way to about 75mph....but was really bad....so I would always slow down. Did it in neutral also...
My fix....new tranny mount. The bushing was shot. We assume it was putting my pinion angle out of limits.
We used a digital accuMASTER digital angle finder and level.
Also, I have watched the video. That (and reading here) is how I figured out that my pinion angle was off in the first place.
Everything helped a little. Biggest difference was when I chucked the poly trans mount and went back rubber. I feel my vibration in my seat.
Another huge difference was with UMI adjustable torque arm. When I had the rear fluid changed I had metal shavings on the magnet.
FYI suspension is all rebuilt.
I talked to Sam Strano and he suggested pinion bearing.
I have a new/used rear with 30k miles going in mine and going to set the pinion angle.
I am not sure how critical pinion angle is, but if you consider for the moment that the car has a trunk and rear seats that if loaded could add approximately 3-400 pounds easily and change the pinion angle.
I think the pinion angle has to be way off for it to be the issue in my case, perhaps in yours as well.
All my efforts have pushed the vibration up in MPH. It is slight at around 90mph. I believe it tends to go away at around 110mph. Logic would indicate that since the rear is under load that the pinion doesn't have as much play???
But I don't claim to be an expert. I just play one on the inter webs.
U joints could also be going out
with suspension mods and lowering the DL geometry is off and sometimes adjusting it to "stock" specs may not resolve vibrations caused by errant DL angles. Maybe try -1
when the shop did adjust DL angle...what was it before they made it -2?
