Pivot, turn signal lever
1979 Chevy Corvette. I am trying to get the part out that the turn signal connects to. Every thing is taken apart and the parts store tells me they need to see the part so they can get me the right one. The turn signal lever has a cruse control wire coming from it. Now looking at the picture with the finger on dimmer switch rod actuator, is that part connected to something or how is it staying in position while other parts are connected? Also i see in the window a round connector where the turn signal slides into it. How can i get that out? My lever is pointing to the ground.
Save the manuals!
Search for "Jazzman Steering Column" on google and you'll get a step-by-step pictoral that will show you all the attachments. If your column matches what the F-Bodies had in the '90's, then the wire will unplug at the column and then the turn signal lever will pull out of the wiper switch, which is mounted in the column.
Beware... Plastic gets old and brittle over time. When I took the stalk out of my '99, it destroyed my wiper switch and I had to take the column apart to put that in so my new lever would have an intact "socket" to go into.
