Sponsored by: CARiD
Unknow electrical issue with the charging system...need help asap!!!
Old Jul 4, 2017 | 12:39 PM
Funkytut98's Avatar
Default Unknow electrical issue with the charging system...need help asap!!!
Hey, I drive a 2002 trans am. I was driving earlier in the day before I broke, however I noticed that when the blinker was depressed that it would take around 10 second pause in between flashes. I just blew that off as a loose connection. (I have no idea if this is pertinent to the situation but I thought I should include). The alternator is not given charge I check the connection and I just had this brand-new alternator dropped in and it not even three weeks ago a new battery. so I have no idea what's going on I have checked every connection leading from the alternator to the car and the battery. I jumped the car off and just watched the volt meter just slowly go down. Idk the problem I need y'alls help!
Old Jul 5, 2017 | 06:38 AM
wssix99's Avatar
Save the manuals!
If you do a search of the site, you'll find many people with similar problems. You'll probably want to start with your exciter wire.
Old Jul 8, 2017 | 07:02 AM
chrysler kid's Avatar
It probably is the alternator. The parts store fbody alternators are notorious for being bad
