Sponsored by: CARiD
Dropping the engine and A/C
Old Jul 25, 2017 | 03:09 PM
sjsingle1's Avatar
Default Dropping the engine and A/C
the last engine I dropped I just vented the Freon......this time I want to keep the system intact.....I read you can keep it intact .....anyone with experience in not breaking the line care to tell me how you did it
Old Jul 28, 2017 | 12:54 AM
eb110americana's Avatar
Since you cannot take the evaporator out with it, I think you'd have to leave the compressor behind. If you can work around this, it should be possible. Otherwise, just have an A/C shop pump down the system for you (as I did, it was free) and then vacuum and recharge after.
Old Jul 28, 2017 | 09:19 AM
King Nothing's Avatar
Cap the lines to avoid getting contamination in the lines. The condenser has to stay also.
Old Jul 30, 2017 | 09:01 AM
qweedqwag's Avatar
Yep just pulled mine out, unbolt it and leave it on the floor it will all move out of the way, disconnect the trans lines first.
Old Jul 30, 2017 | 02:32 PM
Engine out the top?
Old Jul 30, 2017 | 09:06 PM
qweedqwag's Avatar
yes engine out the top, remove the passenger side engine motor mount pedestal the engine will come out easy.
